585,973 active members*
4,182 visitors online*
    Hello
    Does anyone know where the axial configuration in Sinutrain can be set?
    I need axes B and C in addition to X, Y, Z.
    It’s clear about machine’s data… I’d like to declare a new axis after I enter the Siemens’ system password…
    But without success…
    How should it be made in Sinutrain?
    Regards
    <!--sizeo:2--><span style="font-size:10pt;line-height:100%"><!--/sizeo--><!--coloro:#FF8C00--><span style="color:#FF8C00"><!--/coloro--><b>Fehler vermeidet man, indem man Erfahrung sammelt. Erfahrung sammelt man, indem man Fehler macht.</b><!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc-->
    Hello
    If the machine already really exists, you can execute a production initiation (NC) and load it then in the Sinutrain.
    greetings
