584,837 active members*
5,367 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V26: need to remove holes in a hole pattern, not letting me select individual holes
Results 1 to 9 of 9
    Jun 2008
    4
    Hello--first post here so be gentle.
    I just started with BobCAD and am using V26. I am drawing parts to cut on a plasma machine. I want to make a wheel plate with a simple OD of 7" and a hole pattern on a 5.5" center. The wheels have five holes so it is a 5x5.5" pattern, which I have drawn. However, on this plate I only need three of the holes. I cannot figure out how to remove two of the holes in the pattern after it is drawn. Any help would be appreciated.
    Apr 2009
    3376
    Re: V26: need to remove holes in a hole pattern, not letting me select individual ho
    Explode....
    Jun 2008
    4
    Quote Originally Posted by jrmach View Post
    Explode....
    Ohhh, that is HANDY!! Thanks much.
    Next question, if I may-- If I have a text in a block and want to move it once it has already been set, how do I re-select it and move just the text?
    Mar 2010
    1852
    Translate
    Jun 2008
    4
    Quote Originally Posted by Machineit View Post
    Translate
    Thanks for the help!
    Sep 2009
    105
    Whenever I draw a hole pattern I click "Break" in the dialog box and it draws separate circle entities instead of a single hole pattern entity. I usually find this preferable.
    Apr 2008
    1577
    Quote Originally Posted by Ben S View Post
    You should have just said,
    Break...
    LOL :cheers:
    Sep 2009
    105
    Lol, the context of the thread had changed. I thought it might be confusing.
    Jun 2008
    4
    I am trying to make a dxf of a text and I need to connect the center of the Os and As, etc. I drew a line and exploded the image to Trim the parts that I did not want, but it is leaving small lines. How do I remove them to make one continuous cut line?
    Attachment 248282
  1. Cannot select individual edges to create entity.
    By BasuraBlanco in forum EdgeCam
    Last Post: 01-16-2014, 05:23 PM
  2. Replies: 9
    Last Post: 09-18-2012, 12:11 AM
  3. how are thru hole coolant holes made?
    By yoshi900 in forum CNC Tooling
    Last Post: 08-26-2012, 07:50 AM
  4. I want all the way holes on Hole Machining
    By CNC-Dude in forum SprutCAM
    Last Post: 05-09-2011, 11:13 AM
