585,992 active members*
5,428 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Autocad inch to mm
    Good day,
    I have downloaded standard parts from a Canadian website.
    Parts of it are drawn in Inch, so I have no metric value also when I measure it.
    How can convert such parts into MM in ACad2011?
    With best regards
    Kickinger
    HAAS VF7 - BJ2008<br />HAAS ST20<br />HAAS ST10 mit Stangenlader<br />HAAS Mikron VCE1000<br />EMCO 365<br /><br />www.KDC-Technik.at
    May 2005
    27
    scale by factor 25.4?!
    Dec 2001
    5151
    Good day,
    With best regards
    Kickinger
    @ kickinger
    Scale it and change the units- try it with the command ‘unit’ if I remember correctly- it was a while ago.
    If that doesn’t work you can also import the scaled content of the inch file into a metric Acad format…
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
