586,009 active members*
4,659 visitors online*
    Nov 2007
    270
    Hello
    I have another problem with Catia V5R18.
    In a ‘product’ I compressed two hood together, Now I would like to drill through the two compressed parts- unfortunately the drilled hole doesn’t go through both walls .
    Hope you can help me out!
    Regards
    otis Guest
    Hello Jays
    You either have to drill through each part separately, or with the second part state the central point of the first part. You could also undertake the drilling over ‘Component assemblies drilling’ then you can choose the component parts that you want to drill through.
    Regards
    Nov 2007
    270
    Hello Jays
    Regards
    I would like to avoid drilling before merging them together. How would I do it with the function ‘Component assemblies drilling’? Unfortunately I can’t find it!
    Greetings
