585,880 active members*
9,230 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Dissolving of several sub-assemblies
    Aug 2004
    112
    Hello
    I’ve got a problem with an external designer. I received a file as Parasolid x_T that includes many sub-assemblies. I managed to dissolve them only separately. Is it possible to dissolve them all at once?
    Greetings
    vamp21 Guest
    Why don’t you just save the unit externally? Then you’ll have it separately and you’ll be able to edit it without other units.
    If you don’t know how you could make it, write to me. I have to check whether it works in case of this parasolid assembly. But I think it does.
    Greetings
    Vamp
