585,556 active members*
3,579 visitors online*
    Hello,
    I'm using cycle840 and when I'm programming it I have different things to choose: Security distance, angle,.... The last parameter is sense of rotation between one tapping and the next one. Options are M3, M4 and M5. When I choose M5, the second tapping is not working. Machine is waiting. I use:
    T="100140"
    N20 M6
    N25 D1
    N30 s20m3
    N35 f1000
    N40 G00 X0 Y0
    N45 MCALL CYCLE840(10,0,4,,10,0,0,3,20,,1.25,0,1,0,,"ISO_MET RIC","M8",,1001,1)
    N50 G00 X0 z0
    N55 G00 X10 z0
    N60 G00 X20 z0
    N65 MCALL
    N70 m30
    in 840D SL with PCU 50.5
    I'm a service Electronic, not programmer.
    Thank you for your support,
    Mikel
    any help
    any help
    Sep 2018
    TAICNC is a leading manufacturer in China, specializing in the productionVertical Machining Center
    Vertical Machining Center https://www.lvcnc.com/product/vertical-machining-center
    Gantry Milling Machine https://www.lvcnc.com/product/gantry-milling-machine
    CNC Milling Machine https://www.lvcnc.com/product/cnc-milling-machine
