585,975 active members*
4,392 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > recommendation: long turning machine
    Mar 2005
    185
    I am looking for a long turning machine.
    Here are my expectations:
    - Small number of pieces : maximal 50 work pieces
    - Diameter until 25mm desired, otherwise 20 would be acceptable
    - Length until 250mm if possible, otherwise 200 would be acceptable
    - Optimal with milling tool
    - Only one-sided processing necessary
    Can you recommend me any machines in particular?
    Hello
    A careful quetion: do you know what a long turning machine is? Usually nobody would set up one of these machine for only 50 pieces.
    However have a look at Citizen ,Traub,and the Mercedes under the long tuning machine STAR.
    Regards Michael
