523,662 active members*
2,634 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > APC Alarm - Doosan Puma TL2000
Results 1 to 12 of 12
    Hello
    The alarm "APC" flashes on my Doosan Puma TL2000 with Fanuc 18i-TB.
    Since that I also can’t transmit any programs anymore,
    because the error message "memory overflow" comes up.
    But the memory itself is not full.
    Who knows about this problem.
    I've already informed our Doosan dealer but they will call me back, as usual....
    gruß Klaus
    Hello Klaus
    no alarm number?
    Greetings Guido
    No, unfortunately not.
    There is only a flashing light in the alarm window APC, nothing else...
    gruß Klaus
    In general one says: APC = Communication error, Battery ...
    below here there are some ways to hide more detailed errors!
    Greetings Guido
    PS. the machine is not too old? Therefore I conclude in advance that it’s not a cable problem!
    Yes you are right,
    I just received the info from the dealer,
    it is a battery alarm,
    But the memory overflow must be another problem...
    gruß Klaus
    Yes you are right,
    HI
    Swap the batteries first and have a look if the memory overflow problem still persists - I doubt it.
    Are you working on or with a CF card?
    -> often consecutive fault follow which then magically appear afterwards..
    Little tip! also clean the fans of the drives ;-)
    Greetings Guido
    Junior Member
    Jan 2019
    I don’t know the once from Emco but our firm has a Pinacho Taurus with Fagor 8055. Easy to handle and completely sufficient for simple work that are between CNC and conventional.
    google street view maps
    Member
    Sep 2019
    I had the answer when I finished reading your article!
    Please used cool maps when traveling offline!
    There is only a flashing light in the alarm.Excellent and decent post. I found this much informative, as to what I was exactly searching for. Thanks for such post and please keep on sharing with us.The web development company in Riyadh provide good service of web development and design from https://www.adwebstudio.com/web-desi...h-saudi-arabia
    Great blog.Hoping, that you will continue posting articles having useful information. Thanks a lot for providing us that great blog.The NYC web designer provide good service from https://digitalsaad.us/
    Re: APC Alarm - Doosan Puma TL2000
    Your post was good and the information that you giving in your post, that was really cool. I like it very much. Thanks for posting this great information with us. Please share more information and I will bookmark to my blog.The Dubai Web Design provides good design service from https://www.adwebstudio.com/
    Member
    Jun 2020
    This is a great blog posting and very useful.SEO Expert Dubai
