586,009 active members*
4,659 visitors online*
Results 1 to 8 of 8
    Hello
    I’ve got a problem with my old Maoh Hansen sinking EDM machine in case of LBL programming.
    An example
    TOOL CALL 1
    CYCL DEF
    LBL 1
    ngfoji
    LBL 0
    TOOL CALL 2
    CALL LBL 1 Rep 1
    The machine takes tool 1 erodes everything ok
    The machine takes tool2 erodes everything ok
    Then it wants to use the tool 2 again
    It ignores LBL 0 somehow.
    Does anyone have a clue?
    Thanks in advance
    Greetings
    Don’t you happen to have the LBL call in LBL?
    Show your program. It’ll be easier to help then
    Greetings
    Greetings
    No, everything is properly, as it should be.
    Show your program.
    It would be easier to understand.
    Or is your program strictly confidential?
    gruß Klaus
    Dec 2001
    5151
    Hello Hans-Michael
    Write your LBL after M30 at the end of the program and call it by T1 and T2 with LBL CALL.
    <b>Gruß / Regards</b><br /><i><b>CNCFanatiker</b></i><br />AdminCrew<br /><br />Wenn wir immer das tun was wir können, dann bleiben wir immer das was wir sind.<br />If we always this act what we are able to do, then we always remain what we are.
    I have already tried that.
    The machine doesn’t know M02 or M30.
    I programmed LBL after M30 when all LBL had been completed.
    The machine processed the LBL with the last EL.
    IT WORKS!
    I wrote LBL after STOP
    And now it works
    Hello
    I would leave Rep 1 out and only write CALL LBL 1
    Regards, Armin Rauleder
    <a href="http://www.ar-com.de/" target="_blank">http://www.ar-com.de/</a>
