Hello guys
I would like to know how you erode threads on a HS3 or a similar Agie machine?
For example when we erode a normal M6 fixing thread ( core hole drilled / material e.g. 1.2343 with approx.52HRC / undersize lateral 0.6mm) then the machine ‘jerks’ for about 2-3 hours until the thread is finally finished.
The whole lot is programmed with the easy-machining cycle of the controller. The desired surface should be around VDI30-33.
We really need some advice how to speed up the process.
Many thanks in advance!
