Hello!
How can I convert dxf files into lst? Is it possible?
Stefan
Hello!
Stefan
It’s not so easy.
I guess you’ve got a drawing in dxf-format and you’d like to cut it.
It’s assumed that you have a Trumpf-machine. Then you have to convert dxf into .geo first and then make a cutting program (.Lst file) from it. It can be made with a program TRUTops-Laser.
There isn’t a program that converts dxf to Lst…
An Lst-program contains your drawings, material ans cutting parameters.
Point 1: what machine do you have?
Point 2: what programming system do you use?
Point 3: what material are you going to process?
