585,914 active members*
3,685 visitors online*
Thread: Error 160
    Hello everybody
    I have the following problem at Mikron vce500 with Fanuc controller, year of manufacturer 1996.
    When I start it, the error 160 “low voltage” occurs and nothing works. The directions from the manual guide were checked. Without success!
    Does anyone know the problem and could help me? Or does anybody know a service-firm that can help?
    Thanks in advance
    CNC-Steppi
    I’ve also had such a problem. If the voltage is ok, it may be possible that the voltage monitoring is defect. You can turn off this monitoring. But I don’t know how. Haas-Service made it for me. Another reason could be the engine control system.
    Gruß Michael<br><br><br><br>
    Mar 2008
    103
    The error 160 usually occurs in connection with other errors. Those other errors localize the problem.
    <!--fonto:Comic Sans MS--><span style="font-family:Comic Sans MS"><!--/fonto-->Das Problem der Maschine steht 30cm vor ihr&#33;<!--fontc--></span><!--/fontc-->
