585,779 active members*
4,036 visitors online*
    Hello
    I bought a CNC turning machine Syil C6 with CNC Super Box and the Mach3 controller software.
    Does anybody happen to know the correct PIN settings for the output signal for X and Z axes and also PIN settings for the spindle speed indication?
    Regards, Sonnee
    MFG <br />Sonnee
    Hello
    Regards, Sonnee
    Hello
    Motor output
    X-axis ---- Step Pin# =3 Dir Pin# =2
    Z-axis ---- Step Pin# =5 Dir Pin# =4
    Output signals
    Output1 ---- Port# =1 Pin number =14
    Output2 ---- Port# =1 Pin number =17
    Spindle relay settings
    Clockwise rotation (M3) – output# =1
    Counter clockwise rotation (M4) – output# =2
    These are my settings shown in a test of 2-axial controlling card.
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Hello
    Motor output
    Output signals
    Regards, InTex
    Hello
    Unfortunately, the machine still doesn’t work. None of the axes wants to move.
    What can be the reason?
    Regards, Sonnee
    MFG <br />Sonnee
    It can have a lot of reasons. Motor current settings. Does your parallel cable suit? I don’t know where you bought the machine.
    Do your stepper have a noticeable holding torque? Does the logic power work?
    You didn’t give us really enough information saying that you need PIN settings. It would be nice to know more details.
