When i try to generate a toolpath ( outside/right) for the outline (please look at the attached drawing). I get this error: No toolpath generated for current parameters. Check Tool can fit into selected vectors at machining parts.
If i select "On" there is no problems.
Generating toolpath for holes ( inside/left) is not a problem.
Any idear why Vcarve pro 6.504 dosent like this drawing?
Best regards
Poul Munch Andersen
Nb. The file upload program dosent like crv files. So you need to change the txt to crv.
