585,733 active members*
4,937 visitors online*
    May 2012
    17
    Unhappy Rust problem with ways ,large cnc mill
    Does any body have good idea how to stop rust staining of ways on my large cnc mill 100" x 44 " travel. It was hauled in winter and got stained 2 years ago .
    I steel wooled it & used fluid film on it ,but it still showing rusting this year . I dont run it every day . I can not put dehumidifier in room (open shop area ) .
    Does any body have a good answer ??
    Jul 2014
    6
    Re: Rust problem with ways ,large cnc mill
    You have two basic ways. Keep the machine warm or keep it treated.
    The machine gets rust due to condensation, which of course occurs when the machine is colder than the dew point. Often what happens is the machine is at whatever the temperature of the building is, then warm moist air moves in and this creates condensation leading to rust. I'm guessing the ways are not mostly over a cabinet or enclosure you can put a light bulb in for warmth.
    What I use for prevention is called Rust Check, which is from a Canadian automobile rust protection company of the same name. They sell a spray can of a light oil based chemical treatment which is good for about a year. Spray it on, you can leave it or wipe it off the next day. You can get a liter bottle from them as well. I expect there are similar treatments available where you are, but if not, try LPS3 - I believe it's a similar concept of an oil based chemical treatment and it seems to have a pretty good reputation.
    Wayne
    May 2012
    17
    Hi Wayne I was thinking of trying a big 400 watt bay light to shine on it . Mill stands 18' high . Mostly i have been trying to run it every day lately . Need to set up oiler some too . Its
    a shame to get rust on such a nice big machine . I didnt realize it was happening till i went to run it other day & wow !
    Does anybody no if moisture will get under metal way guards that i cant see (havent looked yet ? )
    Jul 2014
    6
    So it's a monster mill, wasn't sure if it was a large light duty machine or what. The light will probably help some, perhaps even enough. It would depend on how much it raises the temperature of the mill. How much that needs to be would depend on the conditions. Heat lamps would probably be more efficient, but I've never actually gone this route. Once I got my shop built, it kept my machines dry. Largely due to much more stable temperatures.
    I would recommend looking into buying LPS3 or similar treatments. I've done some testing and the Rust Check product I use works very well. I think spraying down the ways on a yearly basis with a similar product is your best bet.
    As far as rust under the covers, it should only happen in really bad conditions - like when a machine is dripping in condensation, and even then it will be much less of a problem under the covered areas.
    Jul 2014
    18
    What coolant are you using? Some of the less expensive ones do not have a rust inhibitor. We run Castrol MB50. Great product.
  1. Vasco 5000 rust problem
    By joneser12 in forum MetalWork Discussion
    Last Post: 10-18-2015, 01:53 PM
  2. RFQ Mill bearing ways
    By Alan XR8 in forum RFQ (Request for Quote)
    Last Post: 04-04-2013, 05:12 PM
  3. Rust shadow on mill table and some CAT40 tools - how to remove?
    By helocat in forum Uncategorised MetalWorking Machines
    Last Post: 12-20-2011, 04:40 PM
  4. Rust on Ways
    By bctruett in forum Sharp CNC
    Last Post: 03-09-2008, 04:15 PM
  5. Sieg X3 Ways Large Enough?
    By BrendaEM in forum X3/SX3/G0619/G0463
    Last Post: 03-01-2007, 04:43 PM
