585,969 active members*
4,461 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mitsubishi controls > mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5k
    Question mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5k
    Hi
    I need help with the parameters of the spindle motor and encoder.
    I replaced the controller to a NCT ethercat and need to set the parameters to the ethercat Asyn drive.
    I have the original parameter disk but I guess it is in cp/m and I can!t read it maybe it is damaged.
    Does someone have the parameters for this ac spindle motor?
    what is the resolution of the encoder on it?
    thank you for the help
    Dec 2015
    Re: mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5
    What is yours machine???
  1. Feeler DT0 with Mitsubishi Meldas M50 parameter loss.
    By dpelivan in forum DNC Problems and Solutions
    Last Post: 01-10-2012, 10:48 PM
  2. Mitsubishi AC spindle motor SJ-N
    By Gerisz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2010, 12:22 PM
  3. About the spindle motor mitsubishi SJ-45BP
    By daniel_terr in forum Uncategorised MetalWorking Machines
    Last Post: 12-10-2009, 12:11 AM
  4. Mitsubishi spindle motor
    By dovi in forum Mori Seiki lathes
    Last Post: 03-13-2008, 01:26 PM
  5. mitsubishi spindle servo motor
    By intermax in forum Stepper Motors / Drives
    Last Post: 11-08-2006, 02:29 PM
