Apologies in advance for the long rambling post.
Can anyone supply actual settings for a Huangyang VFD driving a 2.2 kW water cooled spindle please? I am looking for someone who currently has a working setup for a 220 v single phase setup. And preferably in Australia where the voltage etc will be the same. Not what you've heard via the brother-in-law or read on this or any other site please, but an actual working unit. :-)
It would seem there are a myriad of different settings out there that get touted as gospel. Even the reset to factory has divergent views. I find on my unit I need to use 1 and not 8 in PD013 to rest to factory settings. If I use 8 nothing happens.
I currently have the following:
PD000 - 0 (to enable editing)
PD001 - 1 (to control spindle via Mach3 input)
PD002 - 1
PD003 - 400
PD004 - 400
PD005 - 400
PD006 - 2.5
PD008 - 220
PD144 - 3000 Apparently this displays top revs correctly at 24000.
The rest is as per factory defaults mainly.
The reason for my asking is that I am having issues with the spindle not starting. I have replaced the spindle with a new one. Same issue. So now I am of the opinion that the VDF has an issue. So I will replace that. Either that will work or I'll have a spare of each. :-)
The spindle and VDF used to work, but after an unfortunate electrical trip it no longer works correctly. So when I get the new one I would like to set it up using the correct and "IN USE" settings. And not a second hand folk lore version so to speak.
So if you are currently using a water cooled 2.2 kw chinese spindle with a matching Haungyang VFD and would not mind sharing your settings I would be most grateful.
Thanks in advance
Anthony, Brisbane
