585,978 active members*
4,377 visitors online*
    Jul 2006
    809
    Hello guys
    That may sound a bit weird now but I need some advice about drilling with a 3,5mm VHM Spibo.
    I am working on a boring machine and the normal machine are more than 30mm plus.
    We need to make through holes with a 3,5mm Spibo into a plate t=15mm.
    IKZ is not available, only an external cooling.
    The time doesn’t matter-the processing only needs to be safe.
    What can you recommend? VC, Fu, chip breaking? Air?
    Oh and S max are 2500 rev/min
    Frohe Grüsse Stefan<br /><br /><div align='center'><!--fonto:Comic Sans MS--><span style='font-family: "Comic Sans MS"'><!--/fonto--><!--coloro:#FF0000--><span style="color:#FF0000"><!--/coloro--><!--sizeo:6--><span style="font-size:24pt;line-height:100%"><!--/sizeo-->Ein Tag ohne lächeln ist ein verlorener Tag<!--sizec--></span><!--/sizec--><!--colorc--></span><!--/colorc--><!--fontc--></span><!--/fontc--></div>
    Hello
    What material do you want to use? Q & T steels , tool steels?
    2500rev/min is a bit scanty . With 40m/min in tool steel you need 3600 rev/min with that diameter.
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Mar 2020
    Re: 3,5mm VHM drill
    I think we dont talk about the same thing.
    Can you post a sketch. I dont know ETG88 but I mean I dont know everything.
    Mar 2020
    Re: 3,5mm VHM drill
    Quote Originally Posted by iosman987 View Post
    Can you post a sketch. ometv chatroulette chat avenue I dont know ETG88 but I mean I dont know everything.
    thanks my issue has been fixed.
