585,898 active members*
5,031 visitors online*
    Hi all
    I would be interested to know if I can program a zero offset on an approximately 15 year old machine, Charmilles Roboform 200.
    For example:
    I programmed an insert, i.e. All electrode values are entered, traverse dimensions, depth, etc. .......
    Now I place a second insert next to it and I want to run the same program again.
    Is it possible?
    If so, how?
    Thank you in advance
    Greetings Higg
    Hello Higg
    I have worked on a Roboform about 20 years ago and at that times it was already possible to undertake a zero offset and then start a program repeat.
    Unfortunately I can not tell you exactly how. For I am already long gone from the area wire EDM and I have no documentation at hand.
    greetings
    Connysophi
    Hi all
    For example:
    Is it possible?
    If so, how?
    Greetings Higg
    Hello Higg,
    One possibility would be using a CMD program and a RBF program
    I would approach each work piece again with EDG or CEN.
    Go to the starting point of the program with MOV, then enter SEP, CP1,.with the second work piece repeat the same but then enter SEP CP2.
    Now a quick CMD program:
    GOP, 1 (machine moves to the starting point, which was stored with SEP, CP1.)
    SPG THREAD
    GOP, 2 (machine moves to the starting point, which was stored with SEP, CP2.)
    SPG THREAD
    MSG END PROG
    My program for RBF e.g. A thread would then be:
    1: PN / THREAD
    2: FROM / X 0, Y 0, Z, 5 (That is equivalent to the ISO command G92 X0 Y0 Z5!!!!)
    9: AXE / Z
    15: AUXF/22
    18: AUXF/26
    21: AUXF/59
    24: FLUSH / EL, 3
    27: 20 ET =-
    28: AT = 1.1
    33: DOWN / L, ET, E, 342
    34: EXPAN / R, (AT) -0250, E, 343
    34: EXPAN / R, (AT) -0160, E, 333
    34: EXPAN / R, (AT) -0120, E, 323
    34: EXPAN / R, (AT) -0080, E, 313
    34: EXPAN / R, (AT) -0050, E, 303, RET
    39: AUXF/55
    43: FLUSH / EL, 1
    45: END
    Now I edit menu commands (CMD Name of program)
    Only one example
    Greetings Kai
