585,974 active members*
4,219 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > Internal grinding at Kell Varia-1500mm
    Hello
    It’s difficult to grind nitrified parts. But I believe it depends on the grinding disc. My question is: who has got experience with it and found the right grinding disk?
    I’d be glad to get help.
    Franz
    Hello
    It shouldn’t be a problem with CBN. I grinded everything but carbide with it.
    Krebs&Riedel offer facilities for everything.
    http://www.krebs-riedel.de/e-home.htm
    Regards, InTex
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Feb 2020
    12
    Re: Internal grinding at Kell Varia-1500mm
    Good morning
    We grind nitrided parts each month with stone wheels with no problem.
    We have ground ceramic coated parts with cbn diamond wheels as well...
    Quote Originally Posted by fh261059 View Post
    Hello
    Franz
    What exactly is your problem?
    Does the wheel stop cutting metal very quickly? Maybe microcracks appear on the part? Different problems may have different solutions
