585,670 active members*
4,334 visitors online*
IndustryArena Forum > Manufacturing Processes > Grinding > what grinding wheels do you use (manufacturer)
    Mar 2008
    13
    Hello
    I just wanted to ask what DIA grinding screw you use to manufacturer HM new tools.
    What feeds are you using? Especially for flute grinding process.
    I recently had a saleman inhouse and I was surprised about all the changes that happened in the last few years.
    Thank you
    Hello
    We grind with grinding wheels from SlipNaxos, Diamant Müller and from Winter for the flute grinding process.
    It depends what thickness your need for the wheels- there are many price differences- it’s really worth comparing the different offers.
    The feeds depend on the machine and if you want to produce the fuse in deep grinding or cyclical. You have to try out a little bit to find the right one.
    Regards Andreas
