585,743 active members*
4,950 visitors online*
    Hello
    With my machine the automated tool change doesn’t work anymore.
    The error is probably caused by a broken switch above the hydraulic spanner. The request is made over 2 inductive switches- the lower one seems to be fine; the upper one doesn’t react anymore and is always on.
    Exchanging by hand is no problem but in the automatic mode I guess the machine calls the switch. Is that maybe a Balluff BES 516-133-M0-C??
    The writing is unreadable.
    Many thanks for your help
    Oct 2007
    123
    Hello kesh,
    If the switch looks like a domino stone, then it has the DMG order number 27068535.
    It costs around 100€. I needed one last week and ordered it in Pfronten.
    It arrived the next day at 9:00 o’ clock.
    Regards
    Mahoist
    Thanks! That’s exactly what it looks like. It is fixed with two little screws.
