585,715 active members*
3,719 visitors online*
    Jul 2012
    hello ........FROM GREECE
    i have one trumpf tc 260.....WITH CC220
    first I had problems with error 277
    I change all the batteries (three batteries) and i made reload....377
    1- AUS EEPROM
    2 - inter password 377
    3- wait one Minute
    4- the soft key Rest will appear
    5-select RESET......
    AND RELOAD 281 FROM EPROM
    Now I have the error 2670
    -NC-FAULT 2670 - SPS TIME INHIBIT
    - PANEL FAULT- CLOCK POWER FAIL.
    AND THE LED READY 2 NOT LIT...ΙΝ ΤΗΕ POWER SUPPLY
    I read the manual and i saw that has to do with plc
    and battery...
    I HAVE CHANGED THE BATTERIES....BYT I DONT HAVE RECHARGE VOLTAGE ΟΝ ΤΗΕ BATTERIES..
    MY VOLTAGE INSIDE THE POWER SUPPLY IS OK +15V..-15V.. 5V..2.7V...
    After RELOAD 377 FROM EEPROM .... the file L444 does not exist
    I Create a folder L444 with text and i make activation.....
    Do I need to set the folder l444....??
    there is another solution ;;
    if you have something to recommend me
    With kind regards
    BELIOS JIM ELECTRICAL ENGINEER
    Arrow
    thank you for your information waterjet
