7500 RPM
at 24 VDC
ITEM 10-903
• Brand new. High speed DC motor. Built-in brake stops motor when current is shut off. Fully reversible. Useful as a servo motor. Can use as high speed grinder by removing brake.
SPECIFICATIONS
• 12-24 VDC
• 1/8 HP at 24 VDC
• 5000-7500 RPM
• 3-9 amp
• Reversible
• Int. duty
• Shaft 5/16" diam. x 3/4"
• Ball bearings
• 5 1/2" x 3" x 2 1/2"
• Shpg. 3 1/2 lbs.
i dont reall how to do the conversion to oz/in
im trying to build a small mill mostly for aluminum and steel cutting so i need some tourqe (seen some great ideas so far in the wood router section)
Can some one do the math(and show there math so i won't have to ask again)
seems to me that if they were geared down they would have plenty of tourqe...but then again ive been wrong b4
thanks
