585,922 active members*
3,620 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Aug 2005
    6
    Servo Motor question
    This may be a silly question but I am new to this. How come nobody is using servo motors on these X3 conversions? I thought a closed loop system was surperior to stepper motor systems.
    Jason
    Sep 2004
    412
    Cost.... usually.
    Servo's cost more, and the controllers for them.
    Alot of people are of the opinion that with the new stronger steppers. You don't miss steps and don't need to worry as much about the servos.
    I have servos for my x2, but they are in a box somewhere, waiting for my garage to be unpacked.
    May 2005
    240
    One thing I don't understand about servos is how they keep a position. Do they just do a balancing act or what?
    Sep 2004
    412
    There is an encoder on the end of the shaft.
    It's a two part device. One part consists of a disc with ultra small index marks. Then other is the encoder which reads where those marks are and if they have moved.
    If it detects a move that wasn't expected the driving software will readjust the servo back to where it's suspose to be.
    May 2005
    240
    The thing I don't get is wouldn't this lead to inaccuracies? Or is the encoder that sensitive to where that movement wouldn't matter?
    Sep 2004
    412
    I'll let you know when I get mine going.
    *grins*
    However I believe that you set the amount of backlash with in your system. Then it takes that into account.
    24221
    With say a 1000 line quadrature encoder the quadrature edge pulses are often detected to increase the resolution x4 so now you have 4000 counts/turn. say with gearing or ball screw, 1 inch represents 4 turns of the encoder, this will then result in a resolution of 16000 counts/inch = 0.0000625/count.
    If the position error is 1 or 2 pulses, then you can see the kind of error or accuracy you would have.
    Al.
    Albert E.
    May 2006
    22
    I have servos on my X3 and they are working really well. The motors cost quite a bit more but the drives are about the same (assuming quality parts like Geckos). I really overkilled it on mine, have 400oz on X & Y and 800oz on the Z. I feared it would not be enough torque to lift the Z in rapids without a spring attachment but it has enough to lift the head plus a buddy off the ground hanging on for dear life!
    Jun 2005
    866
    Your steppers will only miss steps when they are not able to supply the necessary torque. Get motors powerful enough, and it will be okay. With ballscrews, the need is greatly reduced still. You will see the kits available all make use of 23 frame motors, and I believe have good results.
    May 2005
    240
    Mac why haven't you installed a gas spring on it? That was the easiest part for me.
    I wouldn't dare leave the Z unlocked without the gas spring. Do you have to lock it?
    May 2006
    22
    LOL
    I should have, could of used smaller servos!
    May 2006
    22
    The Z gib is tight enough to keep it from falling (usually...).
    May 2005
    240
    Heh
    I was scared to install the Z conversion and ballscrew without the gas spring. I figured it'd just slam down if the gib wasn't locked. I installed the gas spring before anything else.
    Apr 2005
    403
    JL123,
    Don't forget, although the effeciency of the ball screw and ballnut system works against the holding force of the Z axis, there is enough to prevent the head from moving too rapid. I suspect that the downward travel would simulate closer to creeping down vs. slamming down.
    Jun 2004
    445
    Hi there,
    I'm keen to use servos on my next mill (which is still many many months away...), but one of the biggest problems I have found so far while just looking around, is that servo motors are difficult to find. I know people use DC motors from places like the Surplus Centre (I think that's what it is called) and add encoders, but what other options are there?
    I've come across 'proper' servo motors, but those are expensive. Most of the servos I've seen have been from electronic component suppliers and they run well into the hundreds of Pounds each - too much for my hobby use.
    Where on earth are reasonably priced, decent servo motors found (for something like an X3)?
    Regards
    Warren
    Have a nice day...
    Apr 2006
    402
    This seems to be the general German solution:
    http://www.dunkermotoren.de/default.asp?lang=2
    Jun 2005
    866
    I think that DeskCNC sells them, also Homecnc.info sells some. Smaller DC motors with encoders are pretty much it though
    Apr 2006
    844
    Wink
    Quote Originally Posted by Deviant
    Cost.... usually.
    could your post your servo x2??
    thank you..hehe
    Sep 2004
    412
    My x2 never got servo'd. Everytime I start, life kicks me in the butt.
    I think I'm close now, but looking at ordering a taig to remove the possibility of another conversion delay.
    But, I have almost everything for it.
    x2 mill.
    3 250oz servos with 250ppr encoders.
    3 gecko 320s
    1 Dual output 25v 400a toroid
    1 600v 35a bridge rectifier
    120000 UF 80v Capacitor.
    I have all the materials to complete Steele's conversion.
    Need to pickup a break out board and plate to mount everything on.
    Albeit, I'm torn on the taig. I like the travel and the fact that it's ready to go out the door. More or Less. But it looks dinky in all the pictures. More so compared to the x3. I really won't to get something made.
    I think I've invested over 11k in trying to make something now. Between the lathes, mills, building my old shop running power. Then I changed jobs and moved. Got everything in the garage now on my table waiting for the chips to start flying.
    Jan 2006
    481
    Quote Originally Posted by MacCNC
    Hi MacCNC
    what are the chances of some pictures of your setup
    and some details on the conversion.
    where did you buy the servos from ??
    I think everyone is after DC servo motors but the biggest killer is the expense
    cheers
Page 1 of 2 12
