Laser cutting machine is widely used for cutting wood model; now Thunder laser will show you how to cut a chair model using MDF.
Required items:
- 3.5mm plywood
- Low noise air compressor
Thunder Laser used:
Mars130 with 100watt laser tube
Attachment 243060
Recommended parameter:
*the settings are only for reference, users need to find the best settings by testing
Attachment 243062
Step 1
Load the design file to the software and set the parameters, then click “Download” to send the file to the laser cutter.
Step 2
Put the wood sheet to the machine and adjust the focal distance. Move the laser head to suitable place and press “origin” to set the starting point. Then press “Start” to start your job.
Attachment 243064
Step 3
Take out the finished product.
Tips:
1. To make a perfect product, it is strongly suggested to do more tests to find the best power settings.
2. When cutting wood, it is suggested to use strong air flow to the laser head, it will improve the cutting quality a lot.
Design file download:
If you’re unfamiliar with how to operate the machine, please watch the below guiding video.
How to use your laser machine
Attachment 243066
