585,753 active members*
4,122 visitors online*
IndustryArena Forum > MetalWorking Machines > Tree > Tree Journeyman with Dynapath Control
    Apr 2014
    8
    Hi All,
    Been out of CNC machining for a while now, looking to get back into it again slowly. Just bought a Tree J425 with Dynapath Delta 20 control. Powered up this weeked and was able to home and zero machine after a couple of day's playing with it.I mainly program in EIA GCodes and looking for help on how to use fixture offsets. Also, I seem to loose program position whenever I shut machine off. Anyone in the Columbus Ohio area with Dynapath control?
    Feb 2009
    6028
    Re: Tree Journeyman with Dynapath Control
    You will loose position unless you use a fixture offset (E).
    Apr 2014
    8
    Underthetire, thanks for your response, it explains a lot. I will appreciate if anyone can post a simple Dynapath G Code program that uses a couple of (E) fixture offsets and has more than one tool. Thanks in advance all.
  1. Replies: 5
    Last Post: 05-23-2013, 10:53 PM
  2. Tree Journeyman 250 Dynapath 250
    By phatfred8 in forum Tree
    Last Post: 12-20-2012, 06:54 PM
  3. Replies: 4
    Last Post: 03-07-2012, 05:13 AM
  4. Replies: 7
    Last Post: 01-15-2011, 04:03 PM
  5. Replies: 13
    Last Post: 03-07-2009, 10:02 PM
