585,975 active members*
4,399 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki Mills > Mori Seiki NVX 5100 II CNC Mitsubishi M730BM
    First we started to turn on the A - axis. We didn't know how to use the axis and we tried to do the part in a different way, but know when we prepared the machine with the tools to use the milling machine in 3 axis the machine can t be used. It s working but when i press the start button nothing's happend. I understand that i need to put some parameters and to follow some steps but i m lost and my guy how is working with the machine can t start the production. Please if anybody knows how to put those parameters or which steps i need to follow to use the 4-th axis will save my day. Thanks !
    Feb 2009
    6028
    Re: Mori Seiki NVX 5100 II CNC Mitsubishi M730BM
    Is this a Mori ddrt 4th axis? If so, the manual should be in the control, and it tells you exactly what parameters to change.
    Yeah it s the mori with the 4th axis. I spoke with a guy from mori and he gave me the service manual. I have only the operator manual. The ideea is that i solved the problem but thank you for your answer !
    Apr 2013
    4
    Quote Originally Posted by andritoiualex View Post
    Do you mind me asking how you figured it out? I'm also trying to do this. Thanks
    Sep 2021
    43
    DEAR BRO.
    CAN YOU SHARE WITH ME THE SERVICE MANUAL OF THE m730BM CONTROLLER?.
    THANKS YOU SO MUCH FOR YOUR SUPPORT.
  1. Post for mori seiki Nl 2500 sy Mitsubishi maps 3
    By Floo in forum Post Processors for MC
    Last Post: 08-31-2014, 08:21 PM
  2. Mori Seiki DuraVertical 5100 Door Interlock Bypass
    By Perfect Circle in forum Mori Seiki Mills
    Last Post: 01-24-2014, 11:50 PM
  3. Mori DuraVertical 5100
    By TheBigJW in forum Mori Seiki Mills
    Last Post: 08-30-2010, 06:28 PM
  4. Mori Seiki Dura Vertical 40 x 20 Model 5100
    By highspeedmike in forum Haas Mills
    Last Post: 06-26-2010, 01:44 PM
