585,902 active members*
5,130 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > parameter to enable auto operation with edit key on??
    Nov 2013
    Can anyone tell me if there is a parameter that will allow automatic operation to be carried out while the edit key switch is in edit mode? The machine is a Mori Seiki SL253B with MSG500. Our tooling manager does a lot of on-the-fly edits while building fixtures. Thanks!
    Feb 2009
    6028
    Re: parameter to enable auto operation with edit key on??
    If you have the ladder diagram, its in the back with Keep relays and D-Data. I don't have a lathe ladder here.
  1. Extended Edit Parameter?
    By Mill Head in forum Controller & Computer Solutions
    Last Post: 11-29-2019, 06:35 AM
  2. Replies: 3
    Last Post: 06-25-2012, 08:20 PM
  3. Machine parameter edit procedure for FANUC 6T System
    By VENKATESH REDDY in forum Fanuc
    Last Post: 10-13-2011, 10:56 PM
  4. edit key offset parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-28-2009, 03:54 PM
  5. Mazak EIA enable parameter
    By Bakes1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-12-2008, 08:17 PM
