585,991 active members*
5,380 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > Bendable 3/16" Alum. Rod help/thoughts?
Results 1 to 6 of 6
    Sep 2008
    27
    Have Googled & searched, but nothing quite answered my question. Looking for some 3/16 Aluminum rod that-
    - can be bent to a 180 degree angle with a 1/8" radius, or very close
    - is good looking, shiny, silver
    - usefully hard without annealing/torching/etc.
    - with decent machining properties (Simple holes and flat spots)
    Metallurgy is not my strong point! Seems what I've read is mostly stuff that's hard to source, needs heating/annealing/quenching etc. and there must be (?) a grade that's able to simply be bent without cracking, looks good and is still reasonably stiff. And available in small quantities whilst I'm wishing. You chaps always seem to come through, any thoughts very much appreciated! Chris REC
    Dec 2003
    24221
    Re: Bendable 3/16" Alum. Rod help/thoughts?
    You need to shop by grade, this may help.
    Total Materia - Aluminum Grades
    Al.
    Albert E.
    Sep 2008
    27
    Thanks, but it does not. This info is plentiful, but I am not out to become expert in Aluminum and its alloys, just get some real-word first-hand advice. Chris REC
    Jun 2009
    195
    The rad is too tight for the rod your using ! Sounds like the part should be cast or milled .
    Tony
    Sep 2008
    27
    Yup, it's a tight'n! I was considering offering what I had in mind for sale, but I'll just heat & bend a couple for myself. The final product I can't charge much for anyway, so the 'Hassle Factor' has taken it out of the running. Probably work out for the better, I machine metal, but forming is a whole other thang! Thanks Gents, Chris REC
    Jun 2009
    195
    If I remember right mark one side with marker and heat the other till the marker bakes off and your set to bend . Note ware scratches are and direction . Parts can split
    Tony
  1. Your thoughts about the new "Gearotic Motion" software
    By ynneb in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-21-2019, 04:10 PM
  2. Thoughts on "Closing the Loop"
    By Fish4Fun in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-15-2014, 06:43 PM
  3. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  4. Milling - Need 90" X 24"+ X 1" in alum - in NW area
    By ChinookR&D in forum Employment Opportunity
    Last Post: 04-15-2009, 12:46 AM
