585,715 active members*
4,198 visitors online*
Results 1 to 8 of 8
    Jul 2014
    11
    Sodick A320L with Mark EX Control Problems
    Hello everyone! We've been having a problem with our new old EDM for the past several days. Anytime we use a cut operation whether with or without water, the machine errors with a short circuit. I've read that it could be the wire coming into contact with something within the heads, so I attempted to get it to cut without the wire (holding the wire contact by hand) and still it short circuits. I just finished pulling, cleaning and re-installing all the wires (one by one so they don't get mixed up) and yet it still short circuits. It won't even make a cut operation in the middle of the basin with nothing around it! I'm heading out for the day thoroughly defeated. I hope someone has an idea or has seen this before.
    Michael
    Oct 2012
    Re: Sodick A320L with Mark EX Control Problems
    I know this sounds basic, but have you checked the feed rollers don't have a piece of wire wrapped around them? Or that a piece of stray wire isn't touching hte machine chassis and grounding it?
    Flork
    Jul 2014
    11
    There is nothing that I can see. I've had another technician go over it too, so I don't think it's a visible problem unless we both missed it.
    Nov 2004
    164
    Mark your discharge cable connections clearly and try disconnecting them from the power supply to the machine. Then try a test cut. If it still short circuits you can isolate it to a board problem in the power supply or a problem with an actual short circuit somewhere in the machine. Little slivers of wire or slugs can find themselves in the darnedest places sometimes.
    Jul 2014
    11
    This appears to be the case. I have disconnected the cables from the power supply and I still have a short circuit error. At least I can stop looking at the cutting basin and scratching my head. Any fuses or obvious things to look for on the boards?
    Nov 2004
    164
    There is a procedure for pulling boards one by one that my parts dealer has walked me through on the phone before. They can do a rebuild exchange on most of the boards. They are McWilliams EDM and they are located in North Carolina and also have a shop in Detroit metro area. They have treated me good over the years.
    Jul 2014
    11
    Just to let everyone know, it turned out to be a ground wire that somehow came off the board directly behind the main breaker in the Control Unit. Once that was hooked back up and the associated breaker was reset, the problem was fixed. Now I just need to figure out why the U axis started moving erratically this morning. I think we got a lemon.
    Oct 2013
    sodick a320
    Quote Originally Posted by MrTallant View Post
    hello how are you, could you help me with my machine, it presents the same problem, it just does not turn on the green boot spot on the main board, I really appreciate your help
  1. SODICK WIRE EDM MARK 21
    By BKCOM in forum EDM Discussion General Topics
    Last Post: 02-20-2021, 09:03 AM
  2. Sodick EDM machine Model A7C with MARK XI Control - Start up problem
    By rajappa in forum EDM Discussion General Topics
    Last Post: 02-04-2021, 08:57 PM
  3. Sodick A3C-R with MARK IV controll
    By djezowski in forum EDM Discussion General Topics
    Last Post: 01-20-2013, 07:50 PM
  4. Sodick Mark XI EDW AWT Error
    By CDM_EDM in forum EDM Discussion General Topics
    Last Post: 04-05-2012, 04:22 AM
  5. Sodick Mark X1B EDM Machine
    By rajappa in forum DNC Problems and Solutions
    Last Post: 10-23-2007, 03:56 PM
