585,997 active members*
5,068 visitors online*
Results 1 to 6 of 6
    Mar 2013
    6
    Mazak QT8N T32-2 Tool change position
    Hello...
    When i want to move to the tool change position, the machine want to move 101mm over the home position...
    What parameters change the Tool change Position?
    greetings from Germany,
    Peter
    Jan 2011
    350
    Re: Mazak QT8N T32-2 Tool change position
    My guess would be to check your tool change macro program, assuming your machine has always had this problem.
    Mar 2013
    6
    where can i open it?
    Jan 2011
    350
    I think Mazak T32 is with Mitsubishi 300 controls, so there is an edit lock B (that's the data protect key that is on your operator panel) and edit lock C (param 39 of basic specifications is set to 0). Then you should be able to open your O9000-O9999 macro programs, usually O9001 is the one used for tool change.
    Jun 2012
    36
    Hello Friend,
    The tool change position is decided by the parameter P17 and you can set from 1 to 8 depending on your requirement and before doing any changes always note down the original value and do.Refer the parameter manual for description of each setting say 1------meaning,2-------------meaning.
    SHEKAR
    So.. it fix or not?
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  2. How do I change the Tool Change Position?
    By RussMachine in forum Tormach Personal CNC Mill
    Last Post: 01-04-2014, 08:08 PM
  3. Setting tool offsets and tool change position.
    By trishbits in forum CamBam
    Last Post: 02-08-2013, 12:18 AM
  4. MAZAK QT8N stopped with Alarm 039
    By ua6lfj in forum DNC Problems and Solutions
    Last Post: 10-09-2012, 01:49 AM
  5. tool change position on a mazak nexus mill 640m
    By Denis13 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-03-2008, 05:15 PM
