585,917 active members*
3,468 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Running Bridgeport Interact 1 series 2 mill on a rotary phase converter
    Jul 2014
    Hello,
    I am new to CNC and with a bit of luck this week will be the proud owner of a fully functioning Bridgeport Interact 1 series 2 with a TNC2500. I'm going down to see it and apparently it's a nice machine. I intend drip feeding it from a PC.
    I have a single phase workshop here at home and have a nice rotary phase converter from Transwave that currently powers my manual Bridgeport turret mill and my Hardinge HCT chucker (not at the same time). For convenience, I would ideally like to install the Interact here at home using the same (or other more suitable) converter. Although I wouldn't want to do this if it is a risky option that could damage the machine. I do have the option of renting a small area with 3 phase power locally at the cost of £50/month and some inconvenience.
    I was hoping y'all could shed some light on the potential pitfalls of running them on a converter and how you would go about doing it if it is a good idea.
    Dan
    Dec 2016
    5
    Re: Running Bridgeport Interact 1 series 2 mill on a rotary phase converter
    did you end up running it on a rotary phase converter? I have the same machine and i am thinking of doing the same. im just not sure what size converter i need
  1. Getting Bridgeport Series II Interact 2/Heidenhain TNC 151 running
    By maxvdh in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2017, 09:25 AM
  2. Bridgeport Series I Ineract/ Phase Converter
    By las21788 in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2012, 05:04 AM
  3. Running Fadals on a rotary Phase converter
    By Big Daddy in forum Fadal
    Last Post: 04-06-2009, 03:51 PM
  4. running off rotary phase converter
    By Joe Miranda in forum Milltronics
    Last Post: 04-14-2008, 03:19 PM
  5. Rotary phase converter for Bridgeport 2J Series 1 KM-1 2HP setup?
    By modernprecision in forum Bridgeport / Hardinge Mills
    Last Post: 07-02-2007, 12:43 AM
