Hi all first post here. Dare I say it a newbie!! Taking my first steps into CNC and currently trying to put all the electronics for the controller together.
The main components of interest are C10 S REV 1.2 BOB, with KL5056 drivers. With 570oz/in motors purchased from automation technologies, and KL-600-48 12amp power supply. With a parallel cable supplied by them also, so I am NOT using a printer cable. Just to be sure I have ohmed out the all 25 pins on the cable so she is good.
I have literally spent weeks trying all sorts of combinations and testing to get the motors going.
I used this wiring diagram http://www.kelinginc.net/KL-5056WithC10.pdf
I have tried having the jumper for com pins set on 5V and GND, but I currently set to GND
I have a jumper for outputs 2-9 for pull up or pull down. This is currently set to pull up
I have a jumper for outputs 2-9 for input or output, this is currently set to output.
I have tried both EPP and ECP modes on the PC with no apparent difference.
In Mach 3 I have set
Pul- Dir-
X 8 9
Y 6 7
Z 4 5
I initially couldn't get the LED on the C10 to light up but finally figured out that my 5V GND and enable terminals were flipped 180 contrary to the wiring diagram and manual. Once I got the enable jumper and GND to the right terminals bingo the LED came on so I finally had 5V to the C10. I then found I could jog my X in one direction only. I thought sweet just got to figure out this last bit. But after that I have not been able to get the motor to move since.
I have used multimeter on the C10 pins where you would usually plug in the ribbon cable. Using pin 25 as GND and Pin 9 I get 4.65V. when I jog the other direction it drops to 1.61V. Then jog back again and back to 4.65V
I have replicated this for Y and Z axis with GND 25 again and pins 7 and 5 with the same result. I am not really sure but this tells me that Mach3 is communicating with the C10 and Parallel cable is also working.
When I put the multimeter on the terminal 9 output (X dir-) of the C10 and COM (GND) I get a steady 4.9V and when I jog there is obviously no change hence why my motors aren't moving.
I have my E-stop wired up to terminal 10 and it operates as you would expect in Mach3
This is probably information overload. Trying to answer all the questions have you done this or plug that in etc... Just don't know where to go from here. I am thinking another C10 from another vendor they are only $30, but don't want to waste money if is not necessary of course.
I thought it might have been Mach3 or the parallel cable, but after my earlier test I think it is working as it should. I am now down to thinking it is the C10 BOB. I have triple and quadruple checked my wiring. Not sure if it matters but my dip switches on the kl5056 are
1-4 on = 5.9Amp. 5 off 6-8 on = microstep 2.
I have searched and read heaps of the C10 posts but haven't come up with the goods to solve my problem.
Any help or tips or guidance would be appreciated, even regarding another reliable BOB, as I am seriously considering another one. Wishing I had just bought the Gecko 540. Probably would have been milling weeks ago.
Hayden
