585,894 active members*
4,155 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Sino-nsh Vfd Transformer Oil Purifier
Results 1 to 1 of 1
    Aug 2006
    19
    Application
    VFD insulating oil recycling system is mainly used to improve the properties of insulation oil. It can remove trace water, gas, particulate matters etc. from the insulating oil effectively and rapidly so as to boost performance of transformers, circuit breakers, mutual inductors, cable and capacitors which has insulation system. VFD oil filtration system specialize in purifying branded oil, insulating oil of high voltage and super high voltage transformer. Additionally, it is suitable for treating low viscosity lubrication oil.
    Description
    Model VFD series utilizes coacervation technology, coalescing technology, separating technology and refined purification technology. Comparing to Model VF series, it add ROOTS vacuum system, second stage of separating system to improve the effect of purification. To remove free, soluble water, carbon, free and dissolved gases and particulate matters from insulating oil effectively and rapidly.
    Products Catalogue
    Insulation Oil Series
    VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
    VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
    VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
    VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
    GER Gas Engine Oil Regeneration System
    Turbine Oil series
    TF Turbine Oil Purifier
    TF-A Turbine Oil Automation Purifier
    TF-R Turbine Oil Regeneration Purifier
    Lubrication Oil series
    LV Lubrication Oil Purifier
    LV-A Lubrication Oil Automation Purifier
    LV-R Lubrication Oil Regeneration Purifier
    Flame-resistant Oil series
    FV Flame-resistant Oil Purifier
    FV-A Flame-resistant Oil Automation Purifier
    Explosion-proof series
    EV Explosion-proof Vacuum Purifier
    EV-A Explosion-proof Vacuum Purifier
    EP Explosion-proof Precision Filtering Purifier
    EP-A Explosion-proof Precision Filtering Purifier
    [email protected]
    http://oilpurifier.ec51.com
