What might seem simple to most has me at a loss
I have a boss 5 converted with PMDX 126, GECKO drives, ESS ,MACH3
I want to use a touch plate to find the top of part.
It looks like i would just use 1 wire from PMDX 126 to ground (machine base) to make it work using J12 pin 15
only that pin is isolated from ground (machine base)
it will reference from PMDX J12 ground and trigger input for pin 15 on J12
PMDX manual says not to join ground and machine base or it will take away the isolation of the board
Has anyone figured out where to hook to make this work
i am trying to signal when the tool touches the touch plate which means 1 wire to chassis
i hope this makes sense to someone
PLEASE HELP
HARRY
