585,784 active members*
3,753 visitors online*
Thread: Tool Wear
Results 1 to 10 of 10
    Jul 2010
    172
    Tool Wear
    Hi All
    Got a Haas VF TM2
    Need a little help with setting the offset on a tool.
    I did a pocket with a .5 End Mill which came out .005
    undersize--could you guide me in the right direction
    in setting an offset to compensate for tool ware ??
    Thank you very much--- Rick
    Apr 2012
    43
    Re: Tool Wear
    Well, first give us some code. There are several ways you can accomplish this.
    Jul 2010
    172
    Re: Tool Wear
    viking73
    Here is a bit of the code to see no G41 is output
    I am using Bobcam to generate the code--
    I think i first need to find out why Bobcam is
    not giving me a G41??
    (FIRST CUT - FIRST TOOL)
    (JOB 1 POCKET)
    (FEATURE POCKET)
    (TOOL #1 0.25 1/4 FLAT ENDMILL - LONG)
    N02 T1 M06
    N03 G90 G54 X0.1067 Y0. S1500 M03
    N04 G43 H1 D1 Z0.3 M08
    N05 Z0.1
    N06 G01 Z0. F5.1
    N07 X0.1711 Z-0.0034
    N08 X0.0622 Z-0.0091
    N09 X0.0607 Y-0.0139 Z-0.0098
    N10 X0.0561 Y-0.027 Z-0.0105
    N11 X0.0487 Y-0.0388 Z-0.0113
    N12 X0.0388 Y-0.0487 Z-0.012
    N13 X0.027 Y-0.0561 Z-0.0127
    N14 X0.0139 Y-0.0607 Z-0.0135
    N15 X0. Y-0.0622 Z-0.0142
    N16 X-0.0139 Y-0.0607 Z-0.0149
    N17 X-0.027 Y-0.0561 Z-0.
    Thanks ----Rick
    Apr 2012
    43
    Re: Tool Wear
    Looks to me like you are just roughing the pocket out. Check your settings, there should be an option for finishing, and that should get you your comp
    Aug 2014
    12
    Re: Tool Wear
    your not using any comp. If you had a G41 that would activate cutter comp. Then if you cut was .005 undersized you could use comp in your tool data. -.0025 or -.005 depending how you have your parameters set up. right now your just cutting with now comp.
    Nov 2007
    479
    Re: Tool Wear
    I know in Mastercam there is an option to either let the "Control" or "Computer" handle the cutter comp. If Control is chosen, then G41/G42 is posted.
    Jul 2010
    172
    Re: Tool Wear
    Thanks Guys--
    I am having someone in Bobcam look at it know
    why it does not output G41 when "it seems i am
    doing everything Right---Will let you know--
    In the mean time i would appreciate an explanation
    of the D# and H# Thank you---- Rick
    Nov 2007
    479
    Re: Tool Wear
    The D# is referring to the tool diameter in the offsets page. The H# is the tool length reference to what ever Z plane you set your tools on in the offset page.
    Jul 2010
    172
    Re: Tool Wear
    djr76--
    Thanks a lot for the explanation
    Very helpful-
    Thanks again---- Rick
    Jul 2010
    172
    Re: Tool Wear
    To ALL--
    I finally got the reason why--
    In Bobcam--you can not get a G41 if you are doing a pocket alone !
    You need to be doing a Profile (with the proper settings)---So if it is
    a pocket for a bearing that you are trying to adjust--You first
    pocket out--leave enough to clean up with a Profile.
    That is what i got so far---Now i will go see how the Haas likes it ??
    Thanks for all your interest and help----Rick
  1. Tool Wear Adjustment
    By nfrees114 in forum Haas Mills
    Last Post: 08-08-2014, 01:04 AM
  2. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  3. No tool wear calculation through MDI
    By duivenhok in forum Fanuc
    Last Post: 04-23-2013, 07:14 PM
  4. Replies: 7
    Last Post: 01-23-2013, 05:46 PM
  5. Tool Wear Compensation
    By tz1238 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-16-2011, 08:19 PM
