YAG Metal Laser cutting machine for thickness up to 12mm carbon steel
GN laser Equipment Features and Technical Advantages
1. The single-chamber structure, power increased to 850W, reduce energy depletion and spare parts service life. Make the machine more stable and efficiency.
2. Pneumatic feeding pump and rubber rolling device integrated as a convenient feeding system which make materials processed so easily get into working scope without any scratching on the surface of materials ( Smoothly and no any trace) and save more polishing works accordingly.
3. We have adopted following exhaust system to keep the dust and smoke far away from the machine, enhance equipment working time and operator' health.
4. Convenient Collecting System to collect the finished convenience, which paired with drawers under the machines, it is convenient for operators to collect the cuttings.
5. Outer lens cutting head support for the length of a variety of specifications focal length of the focusing lens.
6. Inside and outside the double structure enclosed dust control system, security prevent dust from entering the core components of growth in the service life of optical components.
7. Full closed loop digital automatic follow focus system, with a variety of protective devices, no board, touch board automatic alarm shutdown protection equipment.
8. The improvement of tank chain will provide enough shield for circuit and cooling parts between Laser head & moving system, cooling system as well. The Tank chain adopted hard raw material & Can stand high-pressure strike Meanwhile very easy uninstall for inspection request. At most reduce dust effect to inner system.
9. Water chiller for cooling system, our standard cooling system can work under 5degrees Celsius to 40 degrees Celsius. With water deionized galvanized, removal of electrolytic ion.
Applicable Industry
It is widely applied in fabrication industries of advertising trademark, metal structure, cabinets, metal processing, electrical cubicle switchboard, textile machinery, cereal processing machinery, kitchenware, lamps and lanterns, automobile, metal handicraft article, saw blade, electrical component, medical apparatus and instruments, aero-space, ironware, cutting and measuring tool, etc.
After-Sale Service
We can supply engineer go to your country to help you install machine and do training after-service together.
Vedio show:
YAG 850W
CY3015-850W with protective cover 3mm stainless steel cutting.wmv :
goo.gl/poaxl
CY3015-850W 5mm aluminum sheet cutting .wmv
goo.gl/WF36s
CY3015-850W 10mm carbon steel cutting.WMV
goo.gl/NQSE7
Double use YAG laser cutting machine
GN-TP3015 tube cutting .wmv
goo.gl/fAFDp
Irregulous(square, oblate) pipe cutting machine
GN-CT3000
CT3000 cutting stainless steel.wmv
goo.gl/DMS3o
CT3000 oblate tube cutting.wmv
http://goo.gl/yU4Ao
Fiber 1.5mm carbon steel cutting.wmv :
goo.gl/8XZVt
Before send us inquiry, please consider about below questions:
1,Which material do you need to cut ?
2,What is working size and thickness ?
3,What is your business industry ?
GN laser will try our best to help you!
Gn-Cy3015-850W Stainless Steel Laser Cutting Steel Machine with panasonic servo motor
Model Type GN-CY3015-850W
Laser Working Medium Nd+3: YAG
Laser Wavelength 1064nm
Maximum Output Power 850 W
Pulse Width 0.120 ms
Pulse Frequency 0500 Hz
Laser power stability 3 %
Maximum cutting speed 4500mm/min(1mm steel plate)
Maximum cutting thickness 12 mm(depend on material)
Cutting area 3000 1500mm
Working table axial location accuracy 0.08 mm/m
Working table repeating location accuracy 0.04 mm/m
Power supply AC380V/ 5%/50HZ
Cutting gas Oxygen, Nitrogen or air
Gas pressure > 10kg
List Date: 8/6/2014
For more info, click here to view the original listing: YAG Metal Laser cutting machine for thickness up to 12mm carbon steel
On Sale For: $50000 + $0 Shipping
