Application
VFD insulating oil recycling system is mainly used to improve the properties of insulation oil. It can remove trace water, gas, particulate matters etc. from the insulating oil effectively and rapidly so as to boost performance of transformers, circuit breakers, mutual inductors, cable and capacitors which has insulation system. VFD oil filtration system specialize in purifying branded oil, insulating oil of high voltage and super high voltage transformer. Additionally, it is suitable for treating low viscosity lubrication oil.
Description
Model VFD series utilizes coacervation technology, coalescing technology, separating technology and refined purification technology. Comparing to Model VF series, it add ROOTS vacuum system, second stage of separating system to improve the effect of purification. To remove free, soluble water, carbon, free and dissolved gases and particulate matters from insulating oil effectively and rapidly.
Products Catalogue
Insulation Oil Series
VFD Double-Stage High-Efficiency Vacuum Insulation Oil Purifier
VFD-A Double-Stage Vacuum Insulation Oil Automation Purifier
VFD-R Double-Stage Vacuum Insulation Oil Regeneration Purifier
VFD-T Double-Stage Vacuum Insulation Oil Purifier with Tester
GER Gas Engine Oil Regeneration System
Turbine Oil series
TF Turbine Oil Purifier
TF-A Turbine Oil Automation Purifier
TF-R Turbine Oil Regeneration Purifier
Lubrication Oil series
LV Lubrication Oil Purifier
LV-A Lubrication Oil Automation Purifier
LV-R Lubrication Oil Regeneration Purifier
Flame-resistant Oil series
FV Flame-resistant Oil Purifier
FV-A Flame-resistant Oil Automation Purifier
Explosion-proof series
EV Explosion-proof Vacuum Purifier
EV-A Explosion-proof Vacuum Purifier
EP Explosion-proof Precision Filtering Purifier
EP-A Explosion-proof Precision Filtering Purifier
[email protected]
http://oilpurifier.ec51.com
