500W Mini Fiber Laser Cutting Machine (GN-CF2513-500W)
GN-CF2513 500W fiber metal laser cutter
Equipment Features and Technical Advantages
1. The machine uses a moving gantry structure, imported high-precision screw and linear guide, smooth transmission, high precision.
2. Bed with the moving beam as a whole welded structure, roughing after annealing, and then the vibration aging treatment, can completely eliminate the stress of welding and machining, good rigidity, high accuracy can be maintained for a long time does not deform.
3. X, Y, Z axes are imported from Japan servo motor, high-precision, high- speed, high-torque, high inertia, stable performance and durable. Ensure the machine's high speed and acceleration.
4. Using many laser cutting control special function modules, powerful, human-machine interface, easy to operate based on the Windows operating system, fiber laser cutting machine CNC system integrated
5. Independent research and development of personalized nesting software, CNC cutting machine to achieve " full-time cutting, efficient cutting and high - nesting rate cut " core technology is the fundamental guarantee of effective material savings, improve cutting efficiency.
6. Cutting fiber laser head selection U. S. Lasermech produced special cutting head, and capacitive sensing, induction of high precision and responsive, the most stable and reliable performance.
7. Imported high - precision electronic control proportional valve, precise control of the cutting auxiliary gas pressure, in order to achieve the best cutting results.
8. Adopting world leading American IPG fiber laser and laser power;
9. Adopt Germany famous PA open CNC system;
10. Adopt Taiwan YYC gear and rack;
Accuracy standards: German standard more than six, Japanese standard more than two;
High precision gear and rack to ensure the mechanical accuracy over the course of seven meters in the scope of work.
11. Using Japan Panasonic servo motor and drive;
Using advanced Japan Panasonic A5 series servo motor and drive, it is automatic compensation the path of cutting and ensure the cutting precision.
12. Adopt fiber dedicated laser cutting head and automatic tracking system;
Applicable Materials
Stainless steel, carbon steel, alloy steel, silicon steel, spring steel, aluminum, aluminum alloy, galvanized sheet and other metal pipes and tubes.
Applicable Industry
It is widely applied in industrial pipeline processing, explosion-proof equipment, military industry, chemical industry, oil exploration, lamps and lanterns, metal processing, ironware, building, etc.
After-Sale Service
We can supply engineer go to your country to help you install machine and do training after-service together.
Vedio show:
YAG 850W
CY3015-850W with protective cover 3mm stainless steel cutting.wmv :
goo.gl/poaxl
CY3015-850W 5mm aluminum sheet cutting .wmv
goo.gl/WF36s
CY3015-850W 10mm carbon steel cutting.WMV
goo.gl/NQSE7
Double use YAG laser cutting machine
GN-TP3015 tube cutting .wmv
goo.gl/fAFDp
Irregulous(square, oblate) pipe cutting machine
GN-CT3000
CT3000 cutting stainless steel.wmv
goo.gl/DMS3o
CT3000 oblate tube cutting.wmv
http://goo.gl/yU4Ao
Fiber 1.5mm carbon steel cutting.wmv :
goo.gl/8XZVt
Before send us inquiry, please consider about below questions:
1,Which material do you need to cut ?
2,What is working size and thickness ?
3,What is your business industry ?
GN laser will try our best to help you!
No Performance index parameter
1 Cutting area(lengthwidth) 2500mm1300mm
2 X axis route 2500mm
3 Y axis route 1300mm
4 Z axis route 120mm
5 X/Y axis positioning accuracy 0.05mm/m
6 X/Y axis positioning accuracy +0.04mm
7 Maximum speed 70m/min
8 Maximum cutting thickness 6 mm
9 CNC system Weihong
9 Number of phase 3
10 Power rated voltage 380V
11 Frequency 50Hz
12 Total power protection grade IP54
List Date: 8/6/2014
For more info, click here to view the original listing: 500W Mini Fiber Laser Cutting Machine (GN-CF2513-500W)
On Sale For: $90000 + $0 Shipping
