Had one of the tool changer lines rupture. Line nomenclature says 5.5x8 Polyurethane. I can find 5x8mm rated to 175 PSI is the ID critical on these lines?
No.
did you get this fixed?? just had the same thing happen to mine and i was wondering how you did it and where did you get your parts??
Amazon has the tubing https://www.amazon.com/s?k=8mm+polyu...nb_sb_ss_i_1_8
Jim Dawson
Sandy, Oregon, USA
Yes, Parker Legris makes the correct tubing and I bought it on Amazon. There are two sizes 6mm p/n 1025U06 04 and 8mm p/n 1025U08 04 I bought a roll of both and replaced all the line on the machine. Didn't take any time at all. Buy a pair of the cutters that use replaceable box cutter blades and you'll get nice cut ends without effort.
