585,917 active members*
3,447 visitors online*
IndustryArena Forum > CNC Electronics > Hobbycnc (Products) > Hobbycnc pro board potential problem
    Mar 2006
    58
    Dear all,
    I have my homemade cnc router machine based on hobbycnc pro board.
    The machine was working perfectly and with a high precision, X and Y axis have the same setting (steps per unit, velocity and acceleratio,..).
    No scale is set.
    Till the problem arised: the y axis is behaving in a misterious way. Sometimes and frequently and when moving normally , it suddenly accelerates then back to normal speed. In addition , it sometimes travels the asked Distance and other times and unexpectedly travels twice the asked distance exactly.
    Please may you know what might be the cause? Is it a defect in the driver or in the stepper motor? Or .....?
    By the way i use mach3 for control
    Best regards and thx in advance
    Mar 2006
    58
    Re: Hobbycnc pro board potential problem
    Problem solved: it was caused by a tiny corrosion at the back of the y axis settings jumpers causing it to be in full step although the jumper is set to be half step.
    Brushed with a teeth brush and a little alcohol and the problem is gone.
  1. hobbycnc board not working.
    By danielphantom in forum CNC Wire Foam Cutter Machines
    Last Post: 10-10-2013, 05:33 AM
  2. Hobbycnc ez and cnc4pc C11 board
    By Lasr Da Vinci in forum Controller Cards
    Last Post: 10-29-2012, 04:31 PM
  3. hobbycnc board
    By wjbzone in forum CNC Machine Related Electronics
    Last Post: 09-08-2012, 05:07 PM
  4. question about hobbycnc non-pro board
    By maxboostbusa in forum Hobbycnc (Products)
    Last Post: 10-22-2007, 04:29 AM
  5. Potential problem with 201 wiring.
    By LeeWay in forum Gecko Drives
    Last Post: 04-08-2007, 12:49 PM
