Hello all - I have a mycenter 2B with fanuc 11m control. I can't seem to get G54 G55 etc to work the way a typical fanuc mill would. Basically the machine ignores any of those work offset codes and just goes from home every time. I have to use G92 to define the distance from home to the work offset position and it gets annoying to add into posted code at every tool change. eg. G90G92X2.345Y3.756Z-2.786 It seems like every time you send the machine home it resets something so it doesn't know where the workpiece is anymore. Is this manual absolute? right now if I want to set up multiple fixtures I have to type in the different G92 co-ords for each fixture or know the exact distance between fixtures. Anyone have any suggestions as to how I should be doing this more effectively?
