586,009 active members*
4,977 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Haas "x diameter measure" problem
Results 1 to 7 of 7
    Jun 2014
    22
    I'm extremely confused with the "x dia. measure" feature. I sure hope someone can enlighten me as I've spent the best part of the day on this. I have a gang tool set up on the TL-1 lathe with 4 place turret. After setting up the first tool to center drill everything worked fine.
    After centering the second tool, a drill bit, and pressing the "x dia. meas." button the correct x offset is entered in the offset block initially, but the screen prompts to enter the diameter. After entering the diameter the value changes, which locates the drill off center. I'm new to Haas and really like what I see so far, but this really has me confused.
    Really grateful if someone could enlighten me with this situation.
    AJ
    Apr 2012
    43
    Re: Haas "x diameter measure" problem
    The diameter for a drill would generally be entered as zero. And if it's a new machine you can just press f2, and get centerline automatically.
    Jun 2014
    22
    Thanks Viking. If I remember correctly, after pressing f2 nothing happened. I'll take another look tomorrow. Really appreciate the response.
    AJ
    Aug 2010
    27
    Enter zero diameter for a center cutting tool such as a drill or tap..
    Jun 2014
    22
    Thanks for the help, I'm a bushing making machine now! :banana:
    Nov 2006
    490
    I see you got it figured out but I wanted to share the explanation we use when standing at the machines at school. The "enter diam" statement is asking you "what diameter is being cut RIGHT NOW", then the number you type in is cut in half to shift the tool to the center of the workpiece. The machine knows that's what you're trying to do for a turning tool, assuming you're programming at the center of the workpiece of course.
    For a drill/etc I just look at the machine coordinate page then copy down the current position into the X offset. But you can also just tell the machine it's cutting at zero diameter too, whatever works..
    Jun 2014
    22
    Thanks for the info Ydna. Truly appreciate it.
  1. Looking for 3.5-4" OAL 1/4" to 1/2" diameter Ball endmills.. anyone?
    By rhadiem in forum Uncategorised WoodWorking Machines
    Last Post: 02-01-2014, 11:17 AM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Conical Boring 6.968" diameter, down to .250" diameter, over a 7.776" length
    By HaroldSAJS in forum Mechanical Calculations/Engineering Design
    Last Post: 06-08-2012, 09:29 PM
  4. Small batch of Acrylic 80mm-diameter "rings" needed
    By theorie in forum Employment Opportunity
    Last Post: 03-02-2011, 09:47 PM
  5. Replies: 1
    Last Post: 01-05-2007, 04:46 AM
