585,708 active members*
3,948 visitors online*
    Sep 2005
    23
    Red face Need help with axis configuration
    Hello.
    I've built a cnc mill with 2 motors running on x axis. Here's the picture:
    http://www.wwracing.lv/galerija/gall...galds_vol2.jpg
    How can I configure the aditionam A axis so that it acts like x axis? I tried simplu to change the A axis name to X, the result was that in g code vhen I told the machine to go to x 100, both axis acted identicaly, but if I want to jog, there is only one motor running at the time. So, how can I get to run the A axis as an aditional X axis?
    Sorry about my bad english.
    Thank's!
    Wire both drives to the X axis step and direction pins. Like you said, you can name them both X, but you won't be able to jog.
    Sep 2005
    23
    I forgot to mention, that I am using the hobbycnc 4axis drive.
    In this case, should I wire the A axis to the X axis pins simply like this:
    http://www.bildez.lv/bildes/jetijs/v...1156431676.jpg
