585,705 active members*
4,265 visitors online*
IndustryArena Forum > CAM Software > Alphacam > BIESSE 5 AXIS IN ALPHACAM WOODWORKING
    Need help in some things in alphaCAM for a Biesse ROVER C6 5 axis with automatic vacuum cups (eps system) for woodworking pieces version AlphaCam Ultimate router
    our enterprise bought Alphacam because in mine district we don`t have much offer in cam and my boss bought Alphacam
    We have serious problems with Alphacam and i need to know if there is a solution or not
    1- imagine you have done 20 programs but the tools that you use need to be fined your diameter of the saw was 300mm now it`s 299mm diameter our reseller told us that you have to make again every operations in every program you made there is no other way to made that???? i just want to make correct diameter in the tool option not open every operation to correct the diameter we made to correct operations and machining styles everytime
    2 - the sawing option don`t work very well some sawings i tried to make in the simulation made well but in the machine the machine don`t do it i have to make the sawing with the "rough or finish" option
    3 - our machine is recent and biesse has now a automatic vacuum cups system and in alphacam our reseller cannot get this funcioning
    4 - when i make an angular machine alphacam executes rapid aproach to piece before and after the motor gets to the angle i program and executes it with very high speed
    i need to know if there is a solution for these problems
    Apr 2010
    89
    Re: BIESSE 5 AXIS IN ALPHACAM WOODWORKING
    Hi Luix87,
    If no one has helped you yet I might be able to help, send me a Private Message with an email address so we can discuss the problems.
    Regards.
    Oct 2013
    109
    Hi Luix87
    What version of Alphacam are you running? In 2014 R2 there is much more pod automation - https://www.youtube.com/watch?v=kGBe...9aqdjlSASwrR1Q
    Does using machine compensation with the rough finish toolpath solve your issue with tool diameters?? Alternatively you could use a negative stock or change the tool?
    Issue 4 sounds like you need your post edited...
    Dec 2018
    Hi would you have a 3 axis Post for biesse?
  1. Z axis alphacam - Xilog plus
    By ingeniero_j in forum Alphacam
    Last Post: 06-14-2014, 06:18 PM
  2. 5 axis router (carolinas) alphacam
    By BILL WRIGHT CCR in forum Employment Opportunity
    Last Post: 07-26-2011, 06:23 PM
  3. Small or large jobs wanted for 5 axis cnc (woodworking)
    By Shawnm in forum Employment Opportunity
    Last Post: 04-13-2011, 08:38 PM
  4. Woodworking CNC Programmer Homag WoodWop Alphacam
    By doverwindows in forum Employment Opportunity
    Last Post: 02-09-2011, 05:41 PM
