plz help mei have pega 357 and give alarm 1006 machine parameter offhow i fix it???
Check parameters 4024, 4025, and 4026 to your setting sheet. Bit "7" (the first of eight reading left to right) enables the settings of the others in that line. 4024 should be 10000000 because you have a Pega. The settings for the other two would depend on your equipped options but Bit "7" (option byte valid parameter) should be at "1".
When the beam go down they are vibration
and we get this alarm jitter error y1 (the press type gecko)
