585,956 active members*
4,560 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i Mate-MB Write Protected for Parameter Write
    Aug 2014
    Exclamation Fanuc 0i Mate-MB Write Protected for Parameter Write
    Please help...!!
    I am using AMS MCV-400 VMC . Now For simplicity and 3D modelling I decided to connect with PC . I have a ready RS232C Cable and PC . But the MAchine not responding.
    The Parameter number 100 , 101 are unable to edit since it is " WRITE-PROTECTED". When tried to change the " PARAMETER WRITE : 0 " to " PARAMETER WRITE : 1 " It cannot changed . It remains at 0 . and shows alarm message again as Write-Protected .
    I have VMC machine with RS232C port
    Fanuc i0 Mate -MB
    Please Help Meee... __/\__
    Jun 2004
    511
    Re: Fanuc 0i Mate-MB Write Protected for Parameter Write
    In MDI, push your offset key several times untill you see the Handy page. Parameter Write Enable is there, turn it to a 1. Now you can edit parameters. Be sure to write down the original values before making any edits, and be sure to go back to handy and set P W E back to 0. It is best to make sure you have an backup before changing anything just in case.
    PWE Write Protect Bit
    Parameter 3292 bit 7
    PK5 The KEYPRM signal (memory protection signal, parameter write
    setting) is:
    0 : Disabled.
    1 : Enabled.
    If that is not it then it is being done in the ladder.
    Jan 2009
    117
    Try switching to MDI mode and switching program protect key to edit enable
    Jun 2023
    hello sir, i got a same problem about "write protect" has shown (HNK HB-130, 18iMB)when i edit program or input new program. parameter 3202 # NE9 & NE8 # its already 1 and key memory protect is off, may be any one can help, thank's , best regards (andri)
  1. Replies: 3
    Last Post: 08-22-2014, 08:13 AM
  2. Replies: 3
    Last Post: 04-16-2012, 06:12 PM
  3. WRITE PROTECTED PARAMETERS?
    By jay_dizzle in forum Fanuc
    Last Post: 09-03-2010, 10:11 PM
  4. write protected dwg
    By smudger in forum Autodesk
    Last Post: 09-05-2007, 08:26 PM
  5. write protected
    By stevieboy in forum Autodesk
    Last Post: 06-03-2004, 09:03 AM
