ive just got done ripping apart a keybourd to see if i can connect switches to the hot keys , turns out its a simple board with two terminals ,one terminal has 8 connections the other has 20 , so i took a wire connected it to one connection in one terminal then connected it to a connector in the other terminal ,with notepad on and ready to recieve info i kept trying different connections and had results most of the time ,so now its a matter of figuring out the complete matrix and i should be able to make a deadly control panel using one thru the usb port ,
has anyone done this yet ,and or have any info which may make this easier to figure the combinations
curt
