584,863 active members*
4,831 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Looking for Testers for my new "Step2Linear" (Step/Dir to analog ) module
Page 1 of 4 123
Results 1 to 20 of 61
    Feb 2007
    962
    A lot of people have asked for a Step/dir to Analog board so people can run MACH3 and still use their Analog Amplifiers. Well i've finally made one.
    Its Viper tune compatible and should have the features to do the job. It has a differential +- 10 volt differential analog output, current feedback input and enable output.
    The loop time is much faster now and programmable up to 4000 samples /sec.
    I am testing it on a AMC 80volt analog amp but I would like to have a few people test them on some larger amps on big mills.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
    Jul 2004
    233
    Re: Looking for Testers for my new "Step2Linear" (Step/Dir to analog ) module
    I bought a board from CNC4PC that does this, used for spindle control, with PWM.... What do you expect to sell yours for?
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    Aug 2014
    889
    Your only about a day late for my situation. I ended up building a simple PWM to 0-10V analogue board for my AMC 100A40 spindle drive.
    Being that I use Viper drives already on XYZ axis, your new product would of fit in nicely with the AMC spindle drive.
    How much are you selling them for, as my analogue board is a temporary fix until I find something better.
    With the mill having been down for a couple weeks already, work has backed up considerably, and if my little board fails, I for sure will be calling you. Just don't go crazy on pricing. LOL
    35 to 60 bucks is what I'm looking at if I go with what's out there by the likes of Homan Designs and CNC4PC.
    24216
    Quote Originally Posted by Larken View Post
    But how will I be able to use my A-M-C drives that do not close the PID loop? I cannot close it to Mach.
    Or does this board close an encoder loop?
    Al.
    Albert E.
    Feb 2007
    962
    This isn't for the spindle drive, its for the axis servo drive.
    Al.
    Yes, it closes the loop and turns the analog drive into a closed loop step/dir drive, so the motor is locked waiting for step pulses to move it. You connect the encoder to the Step2linear board and tune the PID using a serial cable and vipertune.
    (There was a board years ago called the pixie that did the same )
    Al, do most drives supply a current monitor output, so i can sense load ? Is there a standard ?
    Aug 2014
    889
    That depends. Some Mach break out boards, like the one I use, don't have a spindle control port, . So to get around that, I use the A axis step and dir pins and convert them from PWM to a analogue voltage.
    It works well and as soon as you have a manual for your board, I will look into it.
    24216
    I don't think there is a standard, for e.g. on AMC 1v out can represent a current (amp) value depending on switch setting the value also varies for each model model.
    Al.
    Albert E.
    Jul 2004
    233
    Sir,
    Are you saying your interface will not work, if "Open Loop"; no encoder?
    24216
    Quote Originally Posted by jeffserv View Post
    Sir,
    How do you run a servo open loop for CNC application??
    Al.
    Albert E.
    Jul 2004
    233
    Can this be used as a VFD control... no encoder feedback, Spindle Speed control? That is what I am asking... Maybe it cannot...
    Feb 2007
    962
    No Jeff, its not for VFDs it for servo amplifiers that control a servo motor for the x,y,z, axis.
    A VFD has a 0-10 volt input, but its too slow an input to control the motor in servo mode. The vfd has its own accel and decel settings.
    An Analog servo amp has + and - 10 volt differential input and has very fast responce to send fwd and reverse power to the motor to hold high speed position.
    A servo drive can be used to control a spindle in closed loop with an encoder, but its tricky because the spindle has a lot of mass and you can't suddenly change its speed or you may blow the drive. So s/w like Mach that could shut off while the spindle is running fast, could accidently stop sending step pulses to the drive, then the spinning mass of the motor generates a huge back emf. So its not recommended without a fail safe spindle controller.
    So this thread isn't about spindles at this time, its just for servo controls
    Quote Originally Posted by G59
    Its listed on my viperservo.com site. (look for the ad here with the snake)
    Feb 2007
    962
    I don't think there is a standard, for e.g. on AMC 1v out can represent a current (amp) value depending on switch setting the value also varies for each model.
    Al.
    I'm getting some feedback from customers drives and these MTS automation drives have a + - 10 volt output on the current monitor.
    Input/Output Interface: Analog Signals
    Velocity Command Input -- Differential input 0 to ±10 Vdc (15 Vdc Max)
    Auxiliary Input --- Differential input 0 to ±10 Vdc (15 Vdc Max)
    Velocity Output --- Select 1.25, 2.07, 3.71, or 4.54 volts per 1000 rpm
    Current Output ---- ±10 volts = ± Peak Current
    The AMC drive i have is a is a 25A8 , it has 2 current output lines.
    CURRENT MONITOR
    Current Monitor. Analog output signal proportional to the actual current output. Scaling is 4.4 A/V. Measure relative to signal ground.
    CURR REF OUT
    Measures the command signal to the internal current-loop. This pin has a maximum output of ±7.25 V when the drive outputs maximum peak current.
    Al, are you familiar with the CURR REF OUT and what it does ?
    Larry
    24216
    This is what I have on P1-9 pin.
    I have never monitored it.
    Al.
    Attached Thumbnails Attached Thumbnails 25A8limit.pdf
    Albert E.
    Jun 2014
    17
    The mill is a lagun 3v model and comes with linear encoder that were used by the heidenhain tnc155. This controller is damaged and I just can't see spending money to fix it. I'm able to move the 3 axis manually as well as modify the speed of the machine and can conclude that the drives and motors are working well. I would like to simply replace the controller with a computer and Mach3 and your board would come in handy.
    Drives: EL.GE AZE-CC4Q with 0+/-10V input
    Motors: isoflux 4.4Nm Torque...3 of them
    Do you think i can use the linear scales on the machine to connect to your step2linear board?
    As Mach 3 does not run closed loop, does this mean that your new board will be able to compensate or detect for positional errors?
    Tuning is done thru a 9pin or 25pin serial? can a usb to serial cable be used?
    Thx for the help...and let me know as soon as the step2linear are ready...i want to try!
    Feb 2007
    962
    Quote Originally Posted by ech2o2 View Post
    - If you can get quadrature outputs from the linear scale then the board can read them. As long as there is no or very little backlash, the scale should work.
    -Mach3 just outputs the Step/Dir count, which is the exact position it expects the machine to be at, in real time. The Step2lin and the drive take care to make sure the motor is at that position.
    -Tuning can be done thru a USB port if you have a USB - serial converter. I don't put a USB on my drives because they are too sensitive to noise (which servo systems love to generate)
    -I should have it ready in a week or two. I'm working on the current sense inputs. I'm using a differential opamp and it looks like it will be able to connect to most amps with no modifications. Some amps output differential and some single ended current monitoring. For the single ended, you just ground the minus input.
    Larry K
    Sep 2014
    10
    Al.
    yeah
    Feb 2007
    962
    Here is the actual board with the connections. The encoder connections are the same as my other viper drives (see v200 manual) .
    I hope to have a full PDF for the Step2Lin soon. I will be adding to Vipertune to add data-logging, current display, 56k baud and other stuff.
    Aug 2014
    889
    I still say, this can be used for a spindle motor provided you have an encoder and the unit, is between breakout board and AMC drive.
    I will have to buy it and see what gives. Now all I need is a spare spindle motor................LOL.
    The advantage would also be, possible reversing of the spindle, and maybe even Rigid Tapping, as this board would be able to give negative voltage.
    I know Larken you don't think it would work, but in theory, it should.
    Feb 2007
    962
    Quote Originally Posted by G59 View Post
    No, i didn't say it wouldn't work, its just hard on the drive if the step pulses stop when the spindle is running full out.
    It Will work, but you may need a drive 2 x the rated motor current and voltage.
    Larry
    Aug 2014
    889
    Aaaaaah, Yes, now I understand.
    But not too worry. As I said, my spindle is driven by PWM (step/Dir) from the 4th Axis terminal. I convert that PWM signal to an analogue voltage and then I feed that into 100A40 AMC drive. 10 Hp motor 3000 rpm and no problems yet. Drive is cool to the touch even after a full day of work.
    Also, their is no issue whatsoever when the voltage goes from 10 volts to 0Volts. All it does is trigger the braking circuit of the drive. It works very well. The spindle stops within 1 second from 3000rpm. I think you have something here that is potentially more then you originally designed. For myself it would be the possibility of reversing the spindle without using relays and getting rid of my home made DAC.
    Let us know when your manual and boards are available. I will buy one just to see what can be done.
Page 1 of 4 123
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Servo processor "upgrade module" - looking for volonteers.
    By H.O in forum UHU Servo Controllers
    Last Post: 03-27-2011, 04:28 PM
  4. Can someone explain "Full step", "Half step", "Quater step", etc. ???
    By danmst3k in forum DIY CNC Router Table Machines
    Last Post: 12-04-2008, 06:13 PM
